91 - 240 power windows will not go down
Old Dec 30, 2009 | 04:07 PM
topshapemike's Avatar
Default 91 - 240 power windows will not go down
I've read through some threads and can't find the answer.
Here is my history. It started with the front passenger window. It would not go down from passenger switch or driver control switch. I replaced all fuses for windows and window relays. Still nothing. All other windows go down. So I opened up door panel and tested motor and regulator. When pressing down bottom motor sounds and moves window about 5mm and then nothing. So I know I am getting power to window motor. When I press up no move, no sound.
So I replace the motor, regulator whole thing. Still doesn't work. So about a month later. No windows will go up or down. Power locks still work fine.
I do hear a definitive click from where the relays are when I press the brake. I don't know if that is connected to my issues.
I'm at a loss. I didn't think it was a relay issue before because all other windows went down, except passenger side.
Old Dec 30, 2009 | 07:22 PM
i8av8's Avatar
had this problem on my '96 accord. replaced the whole window switch panel and solved the problem. hth!
Old Apr 10, 2010 | 07:30 PM
wagondriver's Avatar
Default same power window issue in my 93
Did you ever resolve your issue? my 93 has the same exact issue and it started with the passenger side window. I am trying to save some trial and error time here.
Old Apr 10, 2010 | 08:45 PM
swiftjustice44's Avatar
When only one window is involved I look at the switches first. The contact inside of them looks like a BB resting in a V of tiny thin brass. Rocking the switch one way or another causes the BB to move to one contact or the other. After this many years, a lot of crud can build up. Spilled soft drinks, dirt, rain water when windows are left down. It's not too tough to disassemble them and http://www.swedishbricks.net/contents.html has a great article on repairing them.
mjohnny
Mar 18, 2013 02:35 PM
Business_Socks
Jan 7, 2009 04:05 PM
cm123
Sep 19, 2008 07:20 PM
alpine
Aug 22, 2007 02:03 PM
bardejov
Jan 13, 2007 07:49 PM
