Power windows issues down but not up
Old Aug 13, 2007 | 05:16 PM
alpine's Avatar
Default Power windows issues down but not up
I have this wierd issue, the rear passenger windows goes down via the controls at on the driver seat, but not up, I have to reach around to the rear passenger windows to bring it back up.
Any ideas
Old Aug 22, 2007 | 10:10 AM
D.Oliver's Avatar
Default RE: Power windows issues down but not up
The up and down by reversing the polarity of the voltage to the window motor. The switches not only supply power, but the ground connection also. Contacts are made (normally closed) in switches that are notbeing pressed. One or more of these normally closed contacts is not being made.
Good Luck.
Dennis
Old Aug 22, 2007 | 12:50 PM
montysano's Avatar
It's a nice afternoon's project to remove, clean, and lube the window controls. Loosen the armrests until you can remove the control. Unplug it from the harness. At the bottom of each switch, you can gently pry back a couple of tabs and get to the guts. Very simple, just a ball bearing and a contact. Clean the contacts, lube everything, and you should be fine. This has fixed every power window issue that I've had.
Old Aug 22, 2007 | 02:03 PM
vipul_vips's Avatar
WD40 is your friend. I had the same problem, albeit, the window used to go down but not come up (even from the passenger's seat). Sprayng WD40 and leaving it for a while worked for me.
87 740 turbo wagon
Feb 17, 2014 08:29 PM
mjohnny
Mar 18, 2013 02:35 PM
topshapemike
Apr 10, 2010 08:45 PM
Business_Socks
Jan 7, 2009 04:05 PM
bardejov
Jan 13, 2007 07:49 PM
