91 740 Turbo oil leak
Hey guys today I realized that my 740 is leaking oil from the oil feed pipe that runs from the block to the turbocharger. its leaking were it connects to the block. how do I remove it from the block? Thanks
The oil feed line is attached to the block by a banjo bolt.(see pic)Remove the bolt,the line will be sandwiched between two copper washers.
The washers should be available at most local auto parts store.(take one with you to match up)Also be sure and check the line for cracks where the pipe is welded to the banjo flange.
Dan
Dan
Engine. Seals, Belts, Crankcase Ventilation
from my favorite Volvo FAQ site,
Volvo Maintenance Hints for 700 900 S90 V90 Models
740turbowag
Jan 29, 2015 07:41 PM
steelheaddan
Feb 5, 2011 06:54 PM
