1989 volvo 740 turbo wagon oil leak under filter
Old Jan 29, 2015 | 04:09 PM
740turbowag's Avatar
Exclamation 1989 volvo 740 turbo wagon oil leak under filter
Directly under the oil filter there is a set of pipes coming down and going to the back of the car. Noticed oil leaking and found it was coming from there. Anyone know how I can fix this??
Old Jan 29, 2015 | 07:41 PM
that sounds like the tranmission cooler lines. they go to the radiator and back to the transmission. is said oil red ATF ?
assuming its the transmission cooler lines, you'd determine where they are leaking, and fix it however is appropriate (replacing a length of pipe or hose, a gasket on a fitting, whatever).
VOLVORRD
Sep 30, 2014 11:02 PM
IC53
Apr 8, 2013 02:43 AM
steelheaddan
Feb 5, 2011 06:54 PM
alpine
Aug 12, 2010 04:04 PM
