91 740 wagon
Old Jul 18, 2011 | 11:01 AM
Bruce Triplett's Avatar
Default 91 740 wagon
Where can I get a used radiator or can a leak in a plastic radiator be repaired? In Racine County, Wisconsin. Thank you in advance for your help?
Old Jul 21, 2011 | 07:48 AM
Do not try used radiators. If you can't afford to get a new one, park it until you can or ask someone to help you.
Old Jul 21, 2011 | 09:30 AM
lev's Avatar
lev
You can get a good used radiator from a wrecking yard. Should cost less than half of new. Perfectly fine solution if you don't have the $, and are willing to use some elbow grease and common sense. Your car's radiator interchanges with many other Volvos so it should be quite easy to find used.
Old Jul 21, 2011 | 10:07 AM
Burn Stains's Avatar
Are you talking about the metal radiator on the front of the car, or the plastic reservoir/overflow tank where you fill the coolant system? I would not reuse or fix either, as the system is under pressure.
andrewma
May 16, 2018 01:47 PM
pierce
Dec 10, 2010 02:08 PM
volvoQ's
Sep 26, 2010 01:45 AM
lwrdr2
Jan 19, 2009 04:36 AM
TedH
Mar 20, 2006 08:32 PM
