91 940 turbo uneven sagging
Old Nov 13, 2010 | 10:55 PM
turbo940v's Avatar
Default 91 940 turbo uneven sagging
hello i have a 91 turbo 940 the right rear sits up at normal height but left rear sags and is about half inch above tire and right is about inch in half What would cause it to sag also when i go from a stop it rumbles in rear a little and when extra weight is in trunk it rumbles even worse any ideas
Old Nov 13, 2010 | 11:27 PM
bad suspension bushing(s)?
badly worn shock (especially if its a nivomat autoleveler, I think those were mostly used on the wagons)
bent suspension components ?
the rumbling may be from the drive shaft U joints, or the center bearing, if the rear is sagging more, its exaggerated.
ms000
Jan 2, 2015 11:15 AM
petemoffat
Sep 17, 2009 12:38 PM
Edinburgher
Apr 25, 2008 04:43 AM
JohnB
Oct 28, 2007 12:30 AM
trhillar
Oct 18, 2005 09:32 PM
