'91' 940 turbo, what do these codes mean??
Old Mar 3, 2008 | 09:47 PM
skyflier66's Avatar
Default '91' 940 turbo, what do these codes mean??
Port 2, 113 and 121
Port 6, 214
Can you tell me what these codes mean. Car still won't idle.
Thanks
Old Mar 3, 2008 | 10:43 PM
skyflier66's Avatar
Default RE: '91' 940 turbo, what do these codes mean??
Ok here is an update.
Disconnected the battery to reset codes. Car still won't idle. It's harder to keep running with gas peddle. No codes, no check engine light.
Disconnected maf car idles and the 121 code comes back on port 2 and the check engine light comes on.
Does this mean the Maf is bad or dirty?? Replaced it less then a year ago.
Help?!?!?
Thanks in advance!
Old Mar 3, 2008 | 10:45 PM
If you unplug the mass flow and it idles and won't with it plugged in it is bad.
Old Mar 3, 2008 | 10:50 PM
skyflier66's Avatar
Will it hurt it to drive like that for a little bit?
Old Mar 3, 2008 | 10:52 PM
skyflier66's Avatar
What would make it go bad again so fast??
Old Mar 4, 2008 | 05:42 PM
Must have just been a poor rebuild on the last one.
You can drive it but it will most likely be running way to rich.
healthnt
Jul 6, 2010 12:07 PM
Rustynuts
Feb 21, 2007 01:32 PM
atikovi
Aug 17, 2006 10:20 PM
photomike
Nov 20, 2004 06:26 PM
