91 volvo 240 bad short from starter???
Old Aug 27, 2013 | 04:56 PM
chucky b's Avatar
Default 91 volvo 240 bad short from starter???
my Volvo wont start but the car seems like it has a major short. I tested the small wire going to the starter solenoid and it has power when the ignition is in the on position. I believe it should only have the 12V when you turn the ignition to start. so my question is this. if the solenoid was stuck in the energized position could this create a short that would cause a back feed to the fuse box making things that are off come on such as heater fan etc.. when the key is turned to on?
I tested the starter by jumping across the posts and it does spin but the throw out bearing does not engage. any thoughts would be greatly appreciated.
I believe it all started with a brake light short that was in the tailgate hinge. I have disconnected the wire harnesses on both sides in the roof that feed the tail gate but think that this short back fed to the ignition and more or less soldered the solenoid??
Old Aug 29, 2013 | 10:38 PM
lev's Avatar
lev
No. It didn't.
Your starter's solenoid is bad.
Get another starter before doing too much else.
Old Jan 1, 2014 | 12:01 PM
chucky b's Avatar
it was the solenoid. replace complete starter w/ solenoid problem solved. thanks for the input
dbouley
North East
Aug 23, 2015 11:52 AM
rvdoctor
Jul 29, 2014 12:15 PM
jigen3
Feb 5, 2013 02:07 AM
rooster11
Jul 15, 2009 10:59 PM
jlorgan
Jul 25, 2005 09:45 PM
