91 Wagon
Old Apr 13, 2008 | 06:41 AM
Gotaway's Avatar
Default 91 Wagon
Just got car, Black Smoke out of tail pipe kinda goes away when it warms up. Is itrunning too rich and oil wants to blow by oil filler cap on valve cover after short drive down the street. Any ideas it has new plugs,wires,cap,rotor could PCV valve do this ? 135K Automatic
Old Apr 14, 2008 | 12:32 AM
jonesg's Avatar
Default RE: 91 Wagon
Unless you know the service history,
Be aware that the crankcase pressure can and will blow the rear engine main oil seal out, that requires pulling the tranny to change it. So maintaining the breathing system is important.
I would change the oil trap, flame trap, air filter , clean throttle body and bellows hose from air filter.
Clean or replace all the hoses connecting the breather system.
Install a new seal in the oil filler cap.
Order an intake manifold gasket and throttle body gasket at the same time, its so much simpler to pull the manifold back out of the way to do the oil trap and whilst in there you might want to change the engine coolant sensor. Should cost around $100 in parts from FCP Groton.
Heres the FAQ,
http://www.brickboard.com/FAQ/700-90...ion_A_Treatise
Then I would get after the timing belt unless you know when it was changed.
Exactly where is the PCV valve ?, mine doesn't have one.
Old Apr 14, 2008 | 01:20 PM
Gotaway's Avatar
Thanks I will not drive until thats done. I will take some pictures as I do this work. Started prep for paint. It does look as if there is oil around the rear seal.
91 240 Wagon
82 1100 Suzuki
95 Ninja
Old Apr 14, 2008 | 07:22 PM
jonesg's Avatar
I've read that fixing the breathing system will often cure a leaking rear main oil seal, if it doesn't theres a really good article complete with photos online, definately do-able.
Rear main seal article,
http://cleanflametrap.com/RMS.html
Old Apr 15, 2008 | 06:44 AM
Gotaway's Avatar
The intake was removed.Insidethe intake was dirty. Will get my parts ordered andclean up area. Any ideas on free flowing the exhustechanging the cat and addinga Borla muffler was my plan.
Old Apr 15, 2008 | 06:51 PM
jonesg's Avatar
The guys on the brickboard say the returns aren't worth the expense with performance mufflers.
If you want power throw a V8 in there.
Plenty of them do that. but...why I dunno.
http://www.youtube.com/watch?v=2cChCXYxr0c
Old Apr 15, 2008 | 06:57 PM
Gotaway's Avatar
Got the parts and was able to put back together. Started up runs better no pressure at oil filler cap going to change plugs check points and timing. Change out exhuste next. Paint prep is still in progress. Thanks again it helped alot.
Old Apr 15, 2008 | 07:22 PM
Gotaway's Avatar
I was going to do away with cat and run straight to muffler. The old system is blowing out crap. Had a S10 with 500 ponies to much fuel. Just looking for economy now.
Old Apr 20, 2008 | 03:00 AM
Typhoon's Avatar
ORIGINAL: jonesg
I disagree with that comment (not with you personally). I have a stock 90 745T, and put a 2.5" catback exhaust on it, with a single light truck muffler in the front muffler position. With no other mods I've probably taken a full second or moreoff my 0-100 km/h time, and picked up a fair whack of midrange torque, you know, useable torque. It will think about breaking the tyres loose on teh 1-2 change at full throttle now.
It's a great thing to do and worth the money in every respect, it's far from loud either.
Regards, Andrew.
Old Apr 20, 2008 | 06:55 AM
jonesg's Avatar
They were talking about the sport system sold by IPD, it has an annoying drone at cruise speeds.
Old Apr 21, 2008 | 04:48 AM
Typhoon's Avatar
ORIGINAL: jonesg
Ahh, I see. It amazes me that manufacturers spend time developing bolt in exhaust systems, and allow things like that to happen. A slightly different muffler would fix it.
That's the main reason I use light truck mufflers, large internal passages, but plenty of packing, so if you can fit them under your car (no problems with a 740), they're the way to go, and cost much less than a mirror polished fart can.
Regards, Andrew.
Old Apr 22, 2008 | 11:45 AM
Gotaway's Avatar
Got car painted needs wet sanding and buff. Did the repairs on engine it had stopped smoking now it has started again changed plugs rotor andcap. What next O2 sensor orcat? Check engine lite on again. Got to be something simple... Hate to buy a book but
andrewma
May 16, 2018 01:47 PM
drenman
Aug 23, 2012 03:02 AM
pierce
Dec 10, 2010 02:08 PM
yellow95
Apr 20, 2006 11:15 AM
yellow95
Apr 18, 2006 08:52 PM
