92 240 B230F broken timing belt
Old Feb 23, 2011 | 06:58 PM
mountain lion's Avatar
Default 92 240 B230F broken timing belt
Thanks everyone for the help
Ok, so I purchased special tool #5284 (to sabilize the crank pulley) and after bouncing on the socket wrench I was able to remove the crankshaft bolt. But now I cannot remove the pulley.
Is there a way remove the pulley without going and buying a crank puller?
Thank you,
ML
Old Feb 24, 2011 | 10:09 AM
bubba240's Avatar
It should come off fairly easy once the bolt is removed, you may need to tap the pulley with a hammer.
Old Feb 24, 2011 | 11:53 AM
swiftjustice44's Avatar
If it doesn't come off with so well aimed tapping, you may also consider spraying a penetrant oil such as PB Blaster and allowing it to soak for an hour or two...
Old Feb 25, 2011 | 03:43 PM
Ty,
Questions, questions!! Where do I tap on the pulley and where do spray penetrating oil? Can I pray all over since it's going to eventually evaporate leaving no residue anyway?
Old Feb 25, 2011 | 07:03 PM
jagtoes's Avatar
Originally Posted by mountain lion
Ty,
Spray around the area that you removed the bolt from. I would also tap in the same area. Remember there is rubber in between the outer pulley area and the center section. PB blaster will not evaporate.
Old Jun 23, 2012 | 07:07 PM
hvolvo's Avatar
Question Sorry to hijack this thread . Im changing out my alt belts and need to figuare how to remove the crankshaft belt. Do you need to remove the actual crankshaft bolt to remove the belt or do you loosen the starter /power steering pivot points /adjusters then pry the starter to remove the crankshaft belt? I have the newer crankshaft pulley one piece. not the two piece crankshaft pulley. THanks for the advice
Old Jun 23, 2012 | 08:54 PM
ed7's Avatar
ed7
Yes, you need to remove the crank bolt, harmonic balancer and lower plastic timing belt guard to get the belt off.
Ed
Old Jun 24, 2012 | 12:32 PM
hvolvo's Avatar
Ed
I posted this question on a different thread the car is a 240 stationwagon gas engine .the other thread they said to loosen the ac compressor which i did but the belt still doesnt remove. I guess your right . I have to remove that pulley bolt? The problem with the ac compressor its on a bracket that attaches to the engine. You cant move the bracket since its already against the engine. You need to basically unbolt the compressor from the bracket to remove the belt ? I have a socket to remove the pulley bolt . I just dont have the tool to lock the crankshaft in place. I read the nylon trick . Remve spark plug. insert nylon rope into cyclnder turn engine until it locks. automatic . place in nuetral and to remove pulley bolt counter clockwise?? thanks
wolfman2099
Sep 24, 2014 07:27 PM
mountain lion
Mar 6, 2011 03:44 AM
mountain lion
Feb 27, 2011 01:11 AM
mountain lion
Feb 2, 2011 06:01 PM
jeremygreg
Apr 14, 2010 04:12 PM
