Broken Timing belt on B230F engine
Old Apr 13, 2010 | 08:41 PM
jeremygreg's Avatar
Default Broken Timing belt on B230F engine
I have a 1987 244DL with a B230F engine and my timing belt broke while driving. I've read that that particular engine is an interference engine. Is that true, and if so what am I up against? I have a feeling it might be bad...
Old Apr 13, 2010 | 10:05 PM
On yours just put on a new belt and drive it away.
Old Apr 13, 2010 | 11:00 PM
Les Vegas's Avatar
meaning that it is not an interference engine
so a new timing belt
and all should be well
Old Apr 14, 2010 | 07:06 AM
darkdelta's Avatar
Once upon a time, shortly after I got my 1990 Volvo Wagon (same engine as yours), I tried to start it up, no go. The timing belt had broken had it towed and replaced. That's all it took, the engine was unharmed. You might consider a water pump, along with the tensioner while the belt is being replaced. I change the water pump with each belt change. Good Luck
Old Apr 14, 2010 | 08:11 AM
jeremygreg's Avatar
Thank you! That is good news.. I have a new belt and everything ready to go. Do i risk damaging the engine if i rotate the crankshaft to line up the timing marks? And how exactly do I do that?
Old Apr 14, 2010 | 08:54 AM
Les Vegas's Avatar
you can not hurt anything, because it is non interference
the crankshaft turns twice for each turn of the camshaft
so you need to get the #1 on compression, and then
the only other trick is finding the marks on each pulley
getting them lined up, and belt on.
then if you rotate the crank around twice ( plugs out )
the marks should line up again
you will likely need a picture or a manual to figure it out
and if you have no compression after, you are likely 180 deg.out
Les
Old Apr 14, 2010 | 10:29 AM
jeremygreg's Avatar
Thanks.. got it right. Changed and back in business.
Old Apr 14, 2010 | 04:12 PM
Sofar.'s Avatar
Volvo did make interference pistons but only for their pushrod engines, which have counter-rotating camshafts so there are only two timing gear, neither of which are likely to fail in the engine's lifetime.
wolfman2099
Sep 24, 2014 07:27 PM
mountain lion
Jun 24, 2012 12:32 PM
mountain lion
Mar 6, 2011 03:44 AM
mountain lion
Feb 27, 2011 01:11 AM
mountain lion
Feb 2, 2011 06:01 PM
