92' 240 brake problems
Old Mar 9, 2008 | 06:28 PM
green240wa's Avatar
Default 92' 240 brake problems
changed my rear pads this morning, got everything put back together, went to bleed the system and nothing. peddle goes all the way to the floor, bleed the system 10 or 15 times and still spitting out air/fluid mix. bleed the front also and they squirted out a good streem. any ideas?
Old Mar 10, 2008 | 06:30 PM
Default RE: 92' 240 brake problems
Maybe the master went bad after compressing the calipers to install the pads.
Old Mar 10, 2008 | 06:54 PM
jonesg's Avatar
I've heard that happens often,
so when I did mine I opened the bleeder so the fluid was just dripping out, then compressed the piston into the caliper, fluid squirted out instead of forcing fluid up into the master cylinder.
Looks like a master cylinder rebuildmight be needed.
Old Mar 11, 2008 | 04:06 PM
johnpoach's Avatar
Have you taken the front wheels off? you havent got a wheel cylinder leakin have you? just sayin in case you havent, I say the front wheels. because obviously you have had the rear ones off. cheers John.
nne2jzc
Aug 27, 2011 07:35 AM
smily4689
Jun 20, 2011 07:50 AM
thullz
Nov 7, 2006 09:25 AM
mywifescar
Jan 13, 2006 12:59 PM
fratless
Sep 20, 2004 06:02 PM
