92 740i wagon
Old Jun 2, 2005 | 11:37 PM
hork's Avatar
Default 92 740i wagon
I just got a 92 740i 129,000mi.
It runs choppy at all rpms and temps.
cold start,smooth 1 second then dies,cankeep it running by working the throtle.
unplug AMM and it runs fat but verry smooth and powerfull.
before I buy a new AMM, could anyone offer any advice?
code 113 121 322 and the right 2 pins on the AMM read 0 ohms.
Old Jun 2, 2005 | 11:40 PM
Default RE: 92 740i wagon
If you unplug the mass flow sensor and it runs good chances are the AMM is bad.
Old Jun 2, 2005 | 11:57 PM
hork's Avatar
Thanks for the tip. I'll repost the outcome.
Old Jun 3, 2005 | 02:40 PM
hork's Avatar
wating for new AMM , I see that the flame trap vacume to manifold is plugged with a bolt.
TB is oily as is large tube from flame trap.
any ideas why the last mechanic? did this and what problems it would cause?
Old Jun 3, 2005 | 03:44 PM
Clean everything out and make sure all is connected.
No idea why they did it beside they didn't know what they were doing.
Old Jun 4, 2005 | 06:32 PM
hork's Avatar
I just replaced AMM ( rebuild from AutoZone @ $168.00/exchange )
and the brick runs like new.
reset the codes , test drive , and no fault codes.
thanks again and I'll be hooking up the pvc vac hose. (it seems an aftermarket
cruise control needed manifold vac and now uses the pvc nipple) I will
use a T or install another nipple.
Old Jun 4, 2005 | 08:21 PM
Good Im glad it is running great now.
andrewma
May 16, 2018 01:47 PM
drenman
Aug 23, 2012 03:02 AM
pierce
Dec 10, 2010 02:08 PM
yellow95
Apr 20, 2006 11:15 AM
yellow95
Apr 18, 2006 08:52 PM
