92 volvo 240 ABS Pulses at Low Speeds
Old Sep 21, 2009 | 10:36 AM
tringa's Avatar
Default 92 volvo 240 ABS Pulses at Low Speeds
The ABS acts up when I'm driving at low speeds and applying hardly any pressure to the brake pedal of my 1992 240 DL. The ABS lifts the brake pedal in the same way as if it was locking up. Also, lately the ABS light comes off quite often. Any help is appreciated. Thank you all in advance.
Old Sep 21, 2009 | 10:55 AM
SL8Brick's Avatar
Did you replace any other brake components(ie: brake pads/rotors/calipers) prior to this happening?
Old Sep 21, 2009 | 11:27 AM
tringa's Avatar
Thank you for your reply SL8Brick. No nothing was replaced, everything worked fine until now. I have recently changed the AMM (Air Mass Meter) but I do not think it may be related with the issue.
Old Sep 21, 2009 | 11:48 AM
bubba240's Avatar
Take a look here:
http://www.brickboard.com/FAQ/700-90...sesatLowSpeeds
Old Sep 21, 2009 | 12:13 PM
tringa's Avatar
thanks a lot bubba240, appreciated. I will try to find the way to clean the front wheel speed sensor, if I can find them :-)
parrym
May 7, 2009 02:18 PM
James Bond 007
Jun 19, 2008 04:26 AM
BuildinAs70
Jan 4, 2008 03:27 PM
elderzap
Oct 19, 2007 01:27 AM
DJboozeAlot
Nov 27, 2006 08:54 PM
