93 240 fuel leak.
Old Apr 6, 2011 | 09:25 AM
ndodson's Avatar
Default 93 240 fuel leak.
Hello everybody,
I googled my problem and couldn’t fine an answer. I apologize if this question has already been addressed.
One cold morning i went to start my 93 volvo 240 190K miles. The car started as always, idling rough when cold. When i came back out some 20 minutes later, to go to work, the car was dead. When i tried to start the car back up it wouldn’t start. I noticed that the fuel gage displayed empty. So i grabbed a fuel can and tried to put a few gallons of gas in. Gas started poring out of the back by the fuel tank. It looked like the gas was leaking before it reached the fuel tank but i am not sure. It was coming out very fast. I haven’t noticed any leak before this. I climbed under the car and didn’t notice any obvious signs of damage.
Any suggestions?
Thanks,
Neil
Old Apr 6, 2011 | 11:14 AM
swiftjustice44's Avatar
Could be the fill pipe where it enters into the tank There is a lock clamp and huge rubber gasket there. Or the tank may have rusted out. With the pumps off, gas isn't going to pour out of a bad output hose. You could always crawl under the car when someone adds a small amount of gas and attempt to see the leak. Alternately, I would think there'd be a stain from the leak if you got down and looked immediately after adding a small amount. The poor running immediately prior was probably a result of sucking up all the crap in the bottom of the tank...yet another reason to not drop below a 1/4 tank.
Old Apr 6, 2011 | 11:26 AM
ndodson's Avatar
Thanks for the advice. Didn’t know about the 1/4 rule. The car is virtually rust free. I am the second owner and the car has lived in Alabama the last 10 years. How do i check the lock clamp and rubber gasket? I don’t work on a car very often, that’s why i bought a 240.
Old Apr 6, 2011 | 12:31 PM
ndodson's Avatar
Forgot to mention that the muffler was recently replaced
Old Apr 6, 2011 | 01:11 PM
Well, I've never seen one work loose unless work had been done on it earlier and just wasn't reassembled correctly. The fill tube is metal, unlike many cars, so that isn't usually an issue. Really, if it were me, I'd have a friend pour a quart or so of gas in while I was under the car. A bit messy but a sure fire way to find the leak. Smoking not recommended!!
2008XC70
2001-2013 model year XC70
Dec 20, 2017 03:07 PM
jfremder
Jul 7, 2014 01:34 PM
pinegrovedave
Apr 21, 2014 01:44 PM
jbachus
Jul 15, 2012 05:06 PM
HunnyBunny
Dec 14, 2010 07:18 PM
