850 Fuel Leak at Fuel Pump Wires - IDEAS APPRECIATED!
Old Jul 15, 2012 | 01:12 PM
jbachus's Avatar
Default 850 Fuel Leak at Fuel Pump Wires - IDEAS APPRECIATED!
Thanks for reading...
My '96 850 sedan recently needed a new fuel pump, did it myself, now that is fixed.
Since then, after fill up, the top of the fuel pump assembly where it goes into the fuel tank has begun seeping / leaking fuel, but only after a fill up. If I do not fill up, i.e only go to 17 gallons of fuel instead of the full 18, then no leak.
More info: at first I thought i may not have resealed the fuel pump assembly to tank which is secured by a large nut (about the size of a large peanut butter jar lid). I bought a new gasket and carefully resealed the assembly. Leak persisted.
So then I filled up the tank (topped it off, really) and let the vehicle warm up in the sun. Doing so, I then observed the top of the fuel pump assembly and notice the puddle the forms on the top of the assembly coming from the wires that pass through the assembly and into the tank where the fuel pump is immersed. Ah ha! Full tank, hot day, puddle on top of fuel pump assembly... now I know what is leaking.
But how to fix it? The original junction where the wires pass through the assembly to go from exterior of tank to interior of tank is a soft waxy type of substance. I can't find this stuff as a replacement part, so I'm wondering how to repair with ordinary type of glues or filler.
I'm thinking:
Option 1: Dig out as much of the "wax" as I can and back fill with silicon (RTV).
Option 2: Dig out as much of the "was" as I can and use gas tank repair glue (the fuel pump assembly where these wires pass through is plastic).
Option 3: Some other type of glue?
Option 4: figure out how to get the original "stuff" or "wax" and go about fixing it.
This is a safety issue, and I'd like to be able to top off the tank and not have a leak.
Suggestions or ideas would be most appreciated.
Thanks for reading - Jeff
Old Jul 15, 2012 | 05:06 PM
I haven't done it but the only thing that comes to mind would be a two part epoxy style gas take repair compound. It would be available at any auto parts store.
jesseh
2001-2013 model year XC70
Dec 2, 2014 04:04 PM
PaperKitty
Jan 12, 2012 07:48 PM
volvoline
May 28, 2009 07:25 PM
VBsportbiker
Jul 24, 2007 02:59 PM
josephmartins
Jan 19, 2006 10:31 PM
