93 940 odometer problem
Old Jul 15, 2012 | 11:06 PM
jonc123's Avatar
Default 93 940 odometer problem
<y odometer just stopped working at 212k. Anyone know if this problem is just like the gear problem in the 850's? If not is there a common fix? The speedometer works fine.
Old Jul 19, 2012 | 11:44 PM
Sambar Stag's Avatar
Default Odometer
Yep, the 240's often fail at around 200k mi. It is usually the small gear that fails; if after replacement it still doesn't work, try the larger gear. Even after replacement, there may be too much drag in the system for it to work all the time. Some lube like grafite or silicone may fix that.
my92940GL
Dec 28, 2015 04:22 PM
zloetakoe
Nov 27, 2011 12:39 AM
s10lowrider1994
Sep 11, 2011 07:53 PM
janeofdrama
May 24, 2010 08:02 PM
pisque
Jun 30, 2005 03:03 PM
