93 940 shakes when braking
Old Jan 8, 2009 | 11:54 AM
nick105's Avatar
Default 93 940 shakes when braking
Whenever I press the brakes while moving there is shaking coming from the front of the car. I've had the brakes inspected and they're supposedlyfine.Any ideas?
Old Jan 8, 2009 | 12:17 PM
tedv's Avatar
Default RE: 93 940 shakes when braking
Most likely it is warped rotors,your inspection might have been limited to pads (standard sloppy procedure).
Old Jan 8, 2009 | 12:36 PM
brf0007's Avatar
I would also suggest that it is warped rotors, you may be able to have a good shop "turn" the rotors, meaning they will shave the uneven part off. But that depends on how much metal is left on the rotors, you may just need to replace them.
Old Jan 8, 2009 | 04:57 PM
nick105's Avatar
Most likely I will just replace them if thats the problem. Is there anything special about changing the pads and rotors on this car? I've only done brakes on domestics.
Old Jan 8, 2009 | 05:09 PM
TIPSP's Avatar
Got Boost?
Nothing really "special".
Actually, these cars are pretty simple to change Brakes.
Edit: You can also try this if your rotor is warped:
drive the car on the freeway, and when there is nobody around you step on the brakes pretty good till you come down to about 25
Then repeat this (maybe five or so times)by driving back to ~65 and stepping on the brakes. It should feel a lot better better, but it will not fix it.
joshfrigmont
Jul 19, 2014 04:58 PM
92_240_sedan
Jan 5, 2013 08:10 PM
morrobaybum
Apr 6, 2009 06:43 PM
Parker731
Oct 17, 2006 06:32 PM
jzajzz
May 13, 2006 10:33 AM
