94 940t Replacing the Turbo Intake hose... anything else?
Old Jan 30, 2012 | 06:40 PM
shwebo's Avatar
Default 94 940t Replacing the Turbo Intake hose... anything else?
The hose from my airbox to the turbo is an oily crumbling mess. Ive ordered a new one and am wondering if there is anything else I should look at while I am installing it? Any kind of turbo maintenance?
Never had a turbo before, dont want to miss anything.
thanks!
Old Jan 30, 2012 | 09:00 PM
swiftjustice44's Avatar
While the hose is off, check the status of the turbo shaft for wear. Grap the nut in the middle of the impeller and move it side to side. It should move only a tiny bit, maybe a mm side to side. Then try to pull on the nut and then push. The shaft should not move in or out at all. If it does, it is on its way out. Might make the decision on which to keep easier.
MemphisSlimbo
Dec 10, 2015 09:07 AM
heygoldie
Mar 26, 2013 07:37 AM
shwebo
Feb 24, 2012 12:39 PM
MrBusterGuy
Jul 27, 2006 11:41 PM
