940 with 15g leaking oil return line
Old 07-22-2012 | 05:00 PM
PAVolvo850's Avatar
Default 940 with 15g leaking oil return line
I just got the 15G swap done and I had it up and running. It was doing fine, but I noticed I had a rather large leak at the oil return line, right where it goes into the block, along the pan rail. I had to cut the return pipe and add a short segment of rubber line to get it to fit. At first I noticed it may not have been in perfectly straight. The second attempt found me smearing RTV on the end and getting it further engaged into the block. I left it sit overnight to dry and set up. Now I try it today and it still is leaking?? Is there a sort of rubber ring seal that goes on the pipe? i know some transmission dipsticks have a sort of sleeve type seal that works perfect. It seems a seal is needed to me
Please advise... Thanks!
Cheers, Mike
rspi
03-09-2016 09:17 AM
s40grafton
10-28-2007 10:42 PM
SilentBob
11-14-2006 10:09 PM
v70 2.4t
03-01-2006 03:21 AM
JimKW
02-22-2006 10:36 PM
