Oil not coming from turbo return line??
Old Feb 27, 2006 | 12:27 AM
v70 2.4t's Avatar
Default Oil not coming from turbo return line??
Hi Guys,
Had the volvo v70 2.4t into the mechanic's to replace the turbo return line gasket & O ring..
Well that's not the problem ?, i went down to the shop, the car was on the hoist, the oil leak is coming from the left hand side of the engine just under all the belts, Crank Case? Just on the inside of the wheel under all the belts.. Oil builds up on the tray and leaks out right next to the wheel, Sorry i can't be more specific, my knowledge of volvo's is limited!!
I would like to know a bit more about this problem so if anyone can help i would appreciate it.
My mechanic said the leak was not too bad, he went on to say that all volvo's leak oil.. old or new they all leak is this right...if so i'm going to go crazy..
Thanks
Jamie
v70 2.4t
Old Feb 27, 2006 | 01:09 AM
Default RE: Oil not coming from turbo return line??
How many miles are on the car?
It could very well be A Cam seal leaking.
Did you have an oil change done recently?
Old Feb 27, 2006 | 01:27 AM
v70 2.4t's Avatar
Hi Tech,
The car has about 53000miles or 85000km, Cam seal or cam something? are the words my mechanic used i think, i did a oil change about 5000km ago, it due soon..
How major is the problem. is there much involved in changing the seal.
How many hours labour.
Thanks
Jamie
V70 2.4t
Old Feb 27, 2006 | 02:42 AM
It should be about 4 to 5 hours.
I would have them do the timing belt and tensioner and idler at the same time to be safe.
Old Feb 27, 2006 | 03:52 AM
v70 2.4t's Avatar
Thanks Tech>>
Old Feb 28, 2006 | 05:22 AM
v70 2.4t's Avatar
Tech, if not fixed straight away will it damage the engine ?
Also why in you last post did you say "to be safe"
Jamie
v70 2.4t
Old Feb 28, 2006 | 08:53 PM
You can let it go for a little but I wouldn't wait to long.
The reason I said to be safe is because I have seen the tensioner and/or Idler pulley lock up and come apart at an early milage and throw the timing belt. Then it bends Valves and costs about $2000.00 to $3000.00 to fix.
They will already be there replacing the belt so it will be no more labor. Just the cost of the parts.
Old Mar 1, 2006 | 02:21 AM
v70 2.4t's Avatar
Ok then i see where your coming from.!!
Jamie..
KeithS60&V70T5
May 6, 2010 12:11 PM
redbottle
Nov 5, 2009 09:41 PM
CTE
May 11, 2008 08:21 AM
s40grafton
Oct 28, 2007 09:42 PM
SilentBob
Nov 14, 2006 09:09 PM
