940 cuts off
Old Sep 1, 2007 | 12:45 AM
cndymyfrnd's Avatar
Default 940 cuts off
Hi,
We just purchased a 940, before we bought it, it would start and drive for about 2 miles, warm up and turn off. It would start right back up and then turn off again after about another mile. When we went to pick it up, it wouldn't start, just tried to start butnot turn over. We thought it might be the fuel pump relay but, it still just won't turn over. Any ideas?
Thanks for all your ideas in advance.
Old Sep 1, 2007 | 09:56 PM
tedv's Avatar
Default RE: 940 cuts off
Well, is the battery up? Make sure you have plenty of juice before anything else.
Old Sep 2, 2007 | 03:08 PM
cndymyfrnd's Avatar
Yes, it tries to start but won't turn over.
Old Sep 5, 2007 | 05:27 AM
Beardog's Avatar
it won't turn over, or won't fire?
Old Sep 27, 2007 | 12:44 AM
apeman's Avatar
Same problem I had.
I replaced the fuel pump in the tank. The pump runs for a while then stops. I pulled it out and hooked it up to a battery and it ran, keept fooling with it and the problem arrised. You can try it yourself, the pump will run fine then it just stops...... Went to Autozone bought a $40 pump and bam.. the car was running fine. It was the fix I needed. Hope this helps
Old Oct 2, 2007 | 05:10 PM
outofworkjoe's Avatar
Allso sounds like an bad or dieing power stage,its on the rt inside finder,this sents power to the coil.It has an heatsink on the back,the high temp grease will dry up and cause it to over heat.It uses the same type grease you use on an cpu heatsink.Had the same problem on my 93 940 turbo
72Demon
Sep 23, 2010 08:13 PM
sdehaven4
May 25, 2010 08:23 PM
maitresaman
May 1, 2007 02:02 PM
Italiano86
Feb 3, 2007 10:25 PM
maitresaman
Apr 7, 2006 07:39 PM
