940 door handle removal
Old Apr 12, 2007 | 12:58 AM
LP_Tango's Avatar
Default 940 door handle removal
I have a 1991 940 turbo wagon. The front passenger side exterior door handle is sticking. I want to remove the door handle to see if I can lubricate it. I removed the screw and bolt at the back of the door that are holding the back of the door handle. But it feel like there may be another bolt or screw holding the handle at the front of the handle as the front part of the handle won't move. I don't want to force it as I don't want to bent anything. Does anyone know if there is another screw at the front holding the handle to the door and if there is, how do you get at it?
Old Apr 12, 2007 | 04:13 PM
billofdurham's Avatar
Default RE: 940 door handle removal
There is a screw at the front of the handle. Have you removed the inner doorpanel? That is the only way you can see it and remove it.
Once the inner panel is off you may be able to lubricate all the working parts without removing the handle.
macdodd
Feb 28, 2014 04:20 PM
TMac
Apr 23, 2009 09:21 AM
andrewlittell
Dec 10, 2007 07:39 PM
Shandora
Feb 18, 2006 10:06 PM
soapboxhero
Jan 21, 2006 12:56 AM
