940 hard time re-starting when warmed up then loses power
Old Jan 17, 2010 | 03:15 PM
jsmilde's Avatar
Default 940 hard time re-starting when warmed up then loses power
I've noticed lately that my 940 Turbo starts up fine in the morning (Michigan winter weather). However, if I drive for a while, turn it off and then restart after a short while (say running into the store or something) it turns over quite a bit and doesn't fire up real solidly.
A little while ago, my daughter called and said she couldn't get it started after going into the store. I went over, finally got it started (it acted as though it was flooded) and then started driving home. After a minute or two of driving, it started to lose power and eventually stopped all together.
This seems to be the opposite of what I've seen from other threads I searched where most of the problem occurs when the car is started the first time.
Any ideas?
Old Jan 17, 2010 | 05:34 PM
TIPSP's Avatar
Got Boost?
check engine light? any codes?
bad ect?
bad FPR?
wait for the experts to get on...
Old Jan 17, 2010 | 06:18 PM
jsmilde's Avatar
No indicator lights of any kind.
Old Jan 17, 2010 | 06:32 PM
jsmilde's Avatar
No indicator lights on. The ECT is an interesting possibility that I hadn't thought of and when I did get it started once when my daughter had it stalled out it did act more like it was flooded. I can hear the rear fuel pump running when I turn it over so I'm thinking the FP relay is OK.
Update: I did get it running but couldn't get it to full throttle and it sputtered out. When it was running I heard almost a whistling sound. I can hear the fuel pump relay clicking on an off with the ignition turn. I have to take the key out re-insert it to get it to hum again. I always hear it run for a second after turning it over for a while but I wonder if that is the other pump.
I could smell fuel a bit after it stalled out but I'm not sure if it's from stepping on the gas while it was dying out.
jdthomas50
Feb 4, 2024 09:56 PM
RED27
Aug 15, 2017 12:02 PM
mayland
Aug 25, 2009 09:15 PM
captsupermarket
Jun 20, 2007 03:10 PM
sirjinx
Jul 14, 2006 02:56 PM
