940 issues ( Breaks )
Old Mar 31, 2007 | 05:07 AM
Mars's Avatar
Default 940 issues ( Breaks )
On my 92 940 non turbo some times the break peddle is horrid, going almost to the floor. Some times its 100% normal. Any ideas?
Old Mar 31, 2007 | 11:36 AM
JetTech's Avatar
Default RE: 940 issues ( Breaks )
Sounds like it's time to replace the master cylinder. I say this because if it was a caliper problem or a leak it wouldn't just do it some of the time, it would do it all of the time. If your brake fluid hasn't been changed in a while I've seen where flushing it out can cure brake problems like you're describing. Rust gets into the system and can cause the master cylinder seals to leak internally.
Aeisner
Feb 16, 2007 10:17 PM
colgate41
May 23, 2006 09:31 PM
colgate41
Mar 14, 2006 01:01 AM
colgate41
Dec 16, 2005 08:54 PM
colgate41
Aug 15, 2005 12:45 AM
