940 lumpy steering
Old Apr 13, 2014 | 12:02 PM
empomire's Avatar
Default 940 lumpy steering
My 1997 940 had slightly lumpy steering, every half turn, when I got it in 2007, I suppose it improved and/or I got used to it, it had been unused for a while. Recently I used it very little for 5 weeks, when I did I found the steering worse, it has hard spots at dead centre and every half turn of the wheel. Changed the fluid. Jacked up the front, tried it with no engine, just the same, flooded the column bearings and UJ with WD 40, not much better. The front suspension strut tops are rotating with the front wheels. So, is it the UJ or struts...or something else?
Old Apr 13, 2014 | 01:18 PM
well, if its every 1/2 turn of the wheel, then it pretty much has got to be in the steering column, something is binding, or the U joint is bad.
btw, where are you that you have a 1997 940? they stopped selling 940's in the US after model year 1995.
Old Apr 13, 2014 | 03:22 PM
empomire's Avatar
Thanks for the suggestion, I'm in the UK, you've mentioned this before:
https://volvoforums.com/forum/volvo-...21/#post365775
This car is a complete wreck to look at, but once gave a ride to Neil Armstrong. I got it at 114k, now on 185k.
RCSnyder
1998-2000 model year V70
Dec 13, 2014 11:05 AM
j70wtc
Dec 7, 2009 10:13 AM
crouchy
Mar 10, 2009 12:23 PM
lippy113
Feb 15, 2009 08:56 AM
russ3161
Dec 17, 2008 07:33 PM
