940 Mystery Wiring harness
940 Mystery wiring harness
was ripping apart the trunk liner to clean out everything (surprise, it was filthy) and noticed this random wiring harness, investigated further and found it went under the spare tire and led to nowhere
any ideas what it might be?
when i found it, the plug was off as shown
fyi, white is ground, brown is tail/running lights, green is right turn and brake, yellow is left turn and brake (for brakes, both yellow and green are actuated at once). the Amazon link above is for a typical converter module that goes from the separate turn and brake lights the Volvo has to the 4-wire system, and also takes the trailer light power off a separate power wire from the battery to that module.
87 740 turbo wagon
06-29-2014 12:02 PM
foldingchariot
12-18-2013 03:24 PM
