940 timing belt
Old Apr 19, 2015 | 10:45 AM
stumpy56's Avatar
Question 940 timing belt
I needed to replace the back timing belt cover on my 1992 940GL. I had to remove the upper camshaft gear and intermediate gear. How do you tighten the gears and what is the torque on those bolts?
Thanks
Old Apr 20, 2015 | 06:11 AM
act1292's Avatar
According to my Haynes manual, the torque setting is 37 ft-lbs for the camshaft and half-shaft sprockets. I made myself a counterhold tool. Just a 2x4 with two bolts through it that fit in the sprocket. I then drilled a large hole between the two bolts for the torque wrench to fit onto the camshaft nut.
7zarc7
Mar 24, 2010 07:17 AM
04v70
Jul 17, 2009 11:01 AM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
