940 Turbo, Automatic gear tranmission oil check?
Old Sep 27, 2005 | 03:24 AM
Qamar's Avatar
Default 940 Turbo, Automatic gear tranmission oil check?
What is the exact way of checking the automatic gear transmission oil. The engine should be in the starting mode... And at what level the dip stick should show specially when the engine is worm.
There are two levels shown on the dipstic, MIN / Max, with two different temp levels also
I dont have the user manual also. Pl help, as i dont want the gear transmission to be over filled
Old Sep 27, 2005 | 03:57 AM
Qamar's Avatar
Default RE: 940 Turbo, Automatic gear tranmission oil check?
In continuation of my obove request, i would like to know the total quantity of Gear oil in Liters to be given to the empthy gear box. Any Idea?
Well i forgot to tell you that i have 1998 model
Old Sep 27, 2005 | 08:55 PM
You need to start the car and drive it a mile or 2. Then check the fluid.Max is max level hot Min is max low level cold.
Some dipsticks have a Min and a Max on both sides one for cold and the other for hot.
If you remove the drain plug and let it drain then fill it Holds 3 quarts.
The total system should be like 12 but that is only if you fluch it.
Sorry I only know the quarts and to Lazy to find and convert.
Old Sep 28, 2005 | 02:29 AM
Qamar's Avatar
So you mean to say that after driving the car for a mile or 2, the engine should be in the starting mode and the gear lever should be at the "P" position. While we are checking the level of the oil through the dipstick it should register at the MAX level.
Correct me if i am wrong any where pl....
Old Sep 28, 2005 | 08:29 PM
It should read Max or close to it.
You have everything correct.
Old Sep 30, 2005 | 07:54 AM
Qamar's Avatar
Thanks for your professional help....
Old Sep 30, 2005 | 09:16 PM
Thats what I am here for.
xboxuser
May 15, 2013 02:06 PM
mathieu_p
Jan 19, 2013 02:06 PM
Qamar
Aug 8, 2005 09:52 PM
harbour
Jul 26, 2005 06:09 PM
