940 Turbo, model 1998, Rotors?
Old Sep 28, 2005 | 02:47 AM
Qamar's Avatar
Default 940 Turbo, model 1998, Rotors?
Whenever i apply brakes.my brake padle pulsates and the steering wheel also gets some vibrations. It appears all the four rotors are wraped up.
I am getting a good set of rotors (ALL FOUR OF THEM) from the junk yard. Is it possible that 740 Rotors can be fixed up in my 940.
Old Sep 28, 2005 | 08:32 PM
Default RE: 940 Turbo, model 1998, Rotors?
I don't think so.I believe they are different.
Did you look at prices for new ones yet?
Chances are the other one from the junk yard will be warped as well.
Old Sep 30, 2005 | 07:52 AM
Qamar's Avatar
Today i opened up the front wheels. Found out that the front rotors were ok, only the rubber bushes were weak and there was a lot of play in the arms,(Cant tell you the otem Names) replaced them with the new one. Now i feel there is no vibration in the handle. However when i opened up the rear brake rotors, they were not getting the full marks of the disc pads. Slight portions from the up and down positions. It appears the disc pads are not touching the middle area of the rotors.
The question is are the rotors gone or i should open up the disc pads and level them up on a machine or sand paper and the reinstall them and check?
Or do you think that whenever this happens the rotors are the main culprits?
Old Sep 30, 2005 | 09:15 PM
ROTORS BAD!!!
(Bye the way im not speaking mad with the CAPS.)
Qamar
Sep 8, 2005 08:24 PM
Qamar
Sep 5, 2005 03:36 AM
Qamar
Sep 4, 2005 02:06 AM
Qamar
Aug 4, 2005 11:13 PM
Qamar
Aug 2, 2005 09:28 AM
