940 wont charge ?
Old Mar 29, 2011 | 12:46 AM
kauait's Avatar
Default 940 wont charge ?
hows it going guys i have a 1993 940. bought a brand new alternator had it tested on the machine.. hooked the positive and negative up correctly wont charge the battery at all ?? any info would help
Thanks
Old Mar 29, 2011 | 09:31 AM
lev's Avatar
lev
Are the dash lights OK? Especially the "Charge" one? If that does not come on and then go off, the alternator won't start charging.
Old Mar 29, 2011 | 03:34 PM
kauait's Avatar
yea the charge one doesnt come on #9 .. only two lights come on when i start the car #18 and 19 the fasten seat belts and SRS ....
so could it be a relay or a fuse??
Old Mar 29, 2011 | 08:04 PM
lev's Avatar
lev
This is your charging problem's source... And, no, no relay or a fuse. It's the circuit board on the back of the instrument panel and/or ground. Have to take out the panel and look for cracks, then refloat them with solder, then retighten the screws. The ground point is behind the passenger side kick panel by the computer. Take that off and clean and apply some of your favorite electrical grease. I'do the ground first and see. As a stopgap, rev the motor up to 3000rpm and this should "excite" the alternator to start charging.
Old Mar 29, 2011 | 09:43 PM
swiftjustice44's Avatar
So...was this issue present before you installed the new alternator?
Old Mar 30, 2011 | 04:09 PM
kauait's Avatar
re did the ground ... still wont charge .. so next would be check the instrument panel for cracks ...( removing and unplug the whole panel) correct?
it was wierd one day it stopped charging so first thing was get a new alternator.. and its still not charging ??
Old Mar 30, 2011 | 06:25 PM
troubleshoot reason its not charging BEFORE replacing expensive parts!
Old Mar 30, 2011 | 09:59 PM
lev's Avatar
lev
Yes, take the panel out, and look at the solder at the joints with a magnifying glass-sometimes cracks are not easy to spot.
Sethcarrier
Oct 14, 2014 11:23 AM
burberry
Feb 2, 2014 04:55 PM
Portland940
Aug 24, 2013 04:09 PM
zon
Jul 24, 2009 12:11 PM
issyjosh
Apr 20, 2005 04:31 PM
