Help with 240
Old Mar 20, 2011 | 03:47 PM
xJoshuaDrakex's Avatar
Default Help with 240
I just purchased a 240 a couple of days ago and I'm starting to notice a weird winding sound when I let off the gas pedal. The guy I bought it from said it could be a bearing in the rear end. Any advice on what it could be?
Old Mar 26, 2011 | 12:13 AM
Thanks for the help.
Old Mar 27, 2011 | 03:55 PM
Joseph/TX's Avatar
You're welcome. Most of us don't really know what you mean by "weird winding sound", so that might explain why you didn't get more responses.
The rule of thumb with rear end sounds is that if you get a whine that increases with speed but goes away entirely if you let off the gas, it's probably gear noise. If you get the noise all the time, whether under power or coasting, it's most likely bearing noise.
Old Mar 28, 2011 | 10:31 AM
Thanks for the reply. I wasn't really sure how to explain the sound. As I said it only really happens while coasting and it seems to not happen when I reach speeds of 40 mph or more. I'm going to take it to a shop and let them look at it. Hopefully it is a bearing and nothing else.
Old Mar 29, 2011 | 05:32 PM
Joseph/TX's Avatar
Good luck with it. BTW, I'm assuming you checked the fluid level in the rear end already. Just a thought..
Old Mar 29, 2011 | 08:50 PM
Pugluvr's Avatar
Maybe this will help:
https://volvoforums.com/forum/volvo-...ratures-25500/
Old Mar 30, 2011 | 10:56 PM
Yeah I checked the fluids and all are good. And thanks for the link. I'll let you guys know what the shop says.
mojo
Jan 6, 2013 06:40 PM
uenvyboykin
Dec 29, 2008 02:47 AM
dennisimo69
Apr 16, 2008 06:38 PM
markjenross
Nov 7, 2007 08:02 PM
denbass
Oct 23, 2007 03:45 PM
