'97 740gle fuel pump issue
Old Mar 15, 2010 | 02:45 PM
bigpoppi78's Avatar
Default '97 740gle fuel pump issue
Hi, I recently replaced both fuel pumps on my 97 740 GLE because my car would not start due to the one under the car went bad. (I figured I'd go ahead and replace the one in the tank too). Now it won't turn over at all. Any assistance anyone can provide would be greatly appreciated.
Old Mar 17, 2010 | 10:03 PM
iatotofts's Avatar
What do you mean by turn over? the fuel pump or the engine? You check for loose connections? How about the ground going to the Fuel pump relay?
Old Mar 18, 2010 | 01:13 PM
fredbyte's Avatar
If it won't crank, then it's probably a bad battery or bad (or broken) connection in the ignition system. If it's an automatic, also check neutral safety switch.
Old Mar 18, 2010 | 01:59 PM
bigpoppi78's Avatar
Sorry about that iatotofts... I meant the engine. When I turn the ignition I can hear the fuel pump engaging. So maybe it is a bad ground. Thanks iatotofts and fredbyte. I check your suggestions out and keep you posted.
Old Mar 23, 2010 | 09:16 PM
iatotofts's Avatar
it won't turn over but when you turn the key you can hear the fuel pump "prime?" I would check connection to the starter from the battery ie: loose or broken grounds.. and also from the ignition switch itself
RumcakeBinge
Aug 22, 2011 07:54 PM
spidersilva
Aug 17, 2011 07:23 PM
elguzzy
Nov 22, 2008 10:12 PM
wagoon
Aug 20, 2008 05:56 PM
