Abs module still running after engine shut off?
Old Dec 28, 2009 | 04:00 PM
Brootal's Avatar
Default Abs module still running after engine shut off?
I have a '91 Volvo 940 Turbo. I noticed today that my ABS light came on for the first time ever. I got home, and noticed a humming coming from under the hood even after I shut the engine off. I'm guessing this is the ABS module? It's a black box, says Bosch and "made in germany" and seems to have brake lines coming in and out of it. Well that box kept "running & humming" for 30 mins with the car off. I unhooked the battery cable and it stopped. The brake fluid in the master cylinder is above the min level and seems full. Any idea what I can do here? Is there a reason for this to keep on running/pumping/whatever it does after the engine is shut off? Thank you very much!
Old Dec 29, 2009 | 02:44 AM
Typhoon's Avatar
I can't help you with ABS diagnostics on a 91 940 as they have a different system to my car, but I believe that car SHOULD have on board ABS diagnostics. Wait for someone more knowledgeable to confirm.
As a temporary fix, you can remove the main harness going into teh pump to get teh car driveable again.
Regards, Andrew.
onnoff7
Aug 19, 2009 07:58 PM
KennyRealtor
Mar 8, 2009 11:33 AM
cioara
Apr 8, 2008 10:01 PM
deathbots
Jul 20, 2007 07:45 PM
tennisguy
May 16, 2006 03:13 PM
