ABS Unit Leak
Old Mar 22, 2010 | 01:42 AM
Titan Joe's Avatar
Default ABS Unit Leak
So I'm slowly leaking brake fluid onto my driver's side fender of my car below the ABS unit, joy! Before I have to take it apart and troubleshoot it, does anyone, A: know what might be the culprit or have seen this before? and B: have any diagrams or information on the unit?
My car is an 89 745 Turbo
Old Mar 22, 2010 | 02:44 AM
Typhoon's Avatar
Not rebuildable. If it's not a hose union leaking, you'll need a used unit.
Regards, Andrew.
Old Apr 22, 2010 | 04:31 PM
Titan Joe's Avatar
So I went to wrecking yard and got a new unit. Now I'm going to bleed the system (it's probably for the first time). How should I bleed the ABS unit itself?
Old Jul 9, 2010 | 10:55 PM
Titan Joe's Avatar
So, it's been a few months and no one has posted anything about bleeding the ABS system. I'm still looking for ideas, now the breaks have gotten worse (the pedal goes to the floor) and the clutch pedal also lowers over time (it kills cruise control). It looks like I have a good bit of plumbing to do. I think I need to rebuild both master cylinders. While I'm at it I might replace the flexible hydraulic lines, I'm thinking steel braided. Anyway, any suggestions on the ABS or master cylinders (rebuild, new or something else) would be great. Also, one last thought, the clutch slave cylinder could be leaking, but I don't know if it's likely or not (I need to get under the car and look for leaks but it's over 2000 miles away for now). So I'm looking to see if anyone has had some experience with this as well. Thanks.
Old Jul 10, 2010 | 02:25 AM
volvoguy2323's Avatar
Banned
The pressure bleeder is the ONLY way to go. The 240's have a very specific order the brakes must be bled in. It's not your typical setup, some of the calipers have 2-3 bleeders each.If you don't follow the correct sequence it won't purge all the air. And as far as I know, the only way to bleed ABS is with a pressure bleeder.
Now that I look at my Bentley book, ABS bleed sequence is as follows. Left rear, right rear, left front, right front. This contradicts general procedure which would be Right rear, left rear, left front, right front. "I.E. start from the farthest point from the master cylinder, and work towards it"....good luck hope this helps BUY A BENTLEY MANUAL THEY'RE FANTASTIC!!
91shelby
Jun 20, 2011 06:56 PM
danton
Oct 17, 2010 10:06 PM
tremere613
Jul 21, 2009 12:42 AM
RickB
Oct 5, 2008 08:00 AM
Quincy56
May 16, 2008 08:54 PM
