Hi,
I’ve just replaced the ABS sensor (left front) on my 940, but am unable to locate the connector to plug the new one into.
I’ve already pulled the new cable from the sensor into the engine bay, but a previous owner has been doing some less than ideal work on the wiring harness and has failed to reconnect the cables.
I see 3 loose cables (blue, red and a thicker pink) hanging around the location that the connector should be in.
my question is:
Are these the wires?
And if yes, can i buy a new “female” connector to wire on?
Any help is greatly appreciated.
