AC problems in '91 740 turbo wagon
I have an issue with the AC in my '91 740 turbo wagon. After reading a bunch of threads, I decided to try re-soldering the MCC board. I removed the MCC and melted the solder joints that I saw in the pics in another thread, and a few others where wires connected the board. It didn't look like any were cracked or loose. I didn't think new solder would fit on the joint without making a mess. Put the MCC back in and it still doesn't work. The compressor has recently been replaced, and I am pretty sure I have pressure, and the pressure switch has been checked and is OK. Where do I go from here?
I'd check for voltage further down the chain before doing anything. There's a pressure switch near the firewall that should have +12v coming in, and you can jumper to its output to see if the clutch engages on the compressor. (Three big circles in the pulley will be spinning not sitting still.)
volvoQ's
Sep 26, 2010 01:45 AM
eyyu
Oct 25, 2007 10:08 AM
