AC System Pressure
Old Sep 9, 2011 | 08:54 AM
amazon2's Avatar
Default AC System Pressure
I assumed that I needed to recharge my AC system as it's not blowing very cold. When I hooked up my simple recharge canister and gauge to the correct recharge port, the gauge immediate showed the system pressure to be in the red. I'm told that this means it's been over-charged and that would produce the same symptom I'm experiencing and I need to release the pressure back to the safe zone. How does a "do-it-yourselfer" go about that?
Old Sep 9, 2011 | 02:11 PM
Burn Stains's Avatar
Was the compressor running when you checked the pressure?
Old Sep 10, 2011 | 07:12 AM
jagtoes's Avatar
Start the car up and let it idle at about 1500rpm . Turn on the AC with fan on high and then take a reading. Pressure will always be higher with engine/compressor turned off. Are you still running R12 or do you have 134 in the system.
Old Sep 10, 2011 | 11:49 AM
swiftjustice44's Avatar
Be certain you are checking the correct port if R12. Both fittings are the same size and placing a cannister on the high side can cause it to explode.
bydand
2001-2013 model year XC70
47
Aug 4, 2025 04:52 PM
MntnDewMan
Apr 3, 2024 04:05 PM
brettboze
Mar 26, 2012 06:25 PM
STREETFIGHTER50
Mar 12, 2009 07:29 PM
