Air Mass Sensor
Old Mar 27, 2006 | 04:10 AM
WagHag's Avatar
Default Air Mass Sensor
I'm thinking of upgrading my '90 740 turbo with a high flow air filter. What would happen if I omitted the air mass sensor? Is it an integral component? Would it throw my air/fuel mixture out of whack if I were to remove it from the system?
Old Mar 27, 2006 | 08:44 PM
Default RE: Air Mass Sensor
Are you wanting to try to remove it all the way?
If you do the car will hardly run.
If you put in a High Flow mass flow sensor you might have to upgrade the computer.
Old Mar 28, 2006 | 03:50 PM
WagHag's Avatar
I ask about removing the air mass sensor completly is because I've seen several images online of my same year model with high flow air filters, but I could never find where they put the sensor. I just figured they were removed and some other upgrade was made to accommodate for it. Any suggestions as to where I could find an ECU upgrade? I know they're not cheap.
Old Mar 28, 2006 | 09:24 PM
If you want to remove it all the way you would have to install a Stand alone Fuel system to run Speed Density.
That will run you about $2000.00 to $2500.00.
tkeser
Dec 5, 2006 12:38 AM
jerryman
Oct 28, 2006 07:35 PM
volvogirl850
Sep 23, 2006 03:27 AM
reg
Jan 1, 2006 11:41 PM
floryed
Apr 14, 2005 10:51 AM
