All dashboard lights came on, car still runs.
Old Apr 22, 2011 | 02:40 AM
mountain lion's Avatar
Default All dashboard lights came on, car still runs.
1992 240 sedan 5spd. The following dash lights just came on and the car still starts, runs and sounds fine: break failure light, parking break light, battery light, and the service light as well as the ABS light, however, the ABS has fickered on and off since I bought the car one year ago. 120k miles on car.
ty,
ML
Old Apr 22, 2011 | 02:46 AM
MasterBlaster's Avatar
Broken alternator belt.
Worn out alternator brushes.
Old Apr 22, 2011 | 12:13 PM
thank you Master Blaster "I bet nobody ever told you that you would be jammin until the break of dawn" Master Blaster by Stevie Wonder
Old Apr 22, 2011 | 12:39 PM
bubba240's Avatar
I would measure the battery while it's running to make sure its charging. You should see at least 13.5VDC.
Old Apr 22, 2011 | 09:33 PM
swiftjustice44's Avatar
ABS circuits typically need to see and honest 12 to 12.5 volts constantly or they set a fault code. A failing alternator or poor connections could play into that scenario. I don't think your instrument lights other than the charge light should illuminate from a failure in the charging circuit. Often, that's a symptom of failing/failed contacts in the electrical connector of the actual ignition switch which attaches to the back side of the ignition switch. Next time, try barely moving the key one direction and the other to see if you can get the lights to go out.
Old Apr 22, 2011 | 09:35 PM
Oh...and pull the codes from the OBD.
Old Apr 22, 2011 | 09:40 PM
MASTER BLASTER!!
Old Apr 23, 2011 | 04:23 PM
I went out last night and tried starting my 240 up and she tried to crank over, but after a few cranks she died out and wouldn't start. the battery seemed to fine b/c the lights were strong, and since I live on a hill I bump started her and she drove fine until I had to come to a stop, and then she would die on me. Thankfully I was still on a hill and bumped her again and came home.
thanks everybody,
ML
Old Apr 26, 2011 | 03:37 PM
I went out and bought a rebuilt alternator and put it in......Vrooooom!! back on the road again!
thanks ya'll,
ML
grayjs5099
May 20, 2014 04:27 PM
1993 240
Oct 18, 2012 11:16 PM
QuentinOK
Feb 4, 2010 12:18 AM
1990TURBO740
Apr 9, 2009 06:06 PM
