almost have it fixed one more thing
#21
Yes. Air fuel ratio gauge.
The a/f is controlled with the o2 sensor and computer. It controls the frequency valve for the fuel distributor. The co mixture adjustment only adjusts the metering plate... It's really only for idle control, but it does move the opening position for the meter plunger in the distributor.
#22
Look through this pdf. It gives an over view of the system and settings.
http://www.k-jet.org/files/greenbook...on_repairs.pdf
#23
#24
#25
#26
www.youtube.com/watch?v=c54nlfHaxi4
Heres the video of the exhaust smoking. Dont worry when it took a couple time to start all it was was one of the pipes for the turbo popped off when i was reving it thel the smoke starts after that. good thing it cleared up last night. Hopefully it stays that way when i get home tonight.
#27
#29
#32
#33
#34
Ok runability wise the old girl is running awesome thank you everyone for helping me out. Now im chasing an oil leak. Looks like either the corner of the valve cover, oil sending unit, or a cam seal. It doesnt appear to leak when its idleing in the driveway and im sitting there looking at it. If i go drive around the block a few times probably about 5-10 mins worth of driving the my water pump will be coverd in oil as well as the alternator and the front of the exhaust manifold. Any ideas i can post a pic tomorrow once its light out again
#35
wash it off with gunk and hose water to degrease it and put some UV dye in the oil, then after dark, do a /short/ drive, and hit it with the UV light, I bet it will show right up.
oil on the front exhaust side of the valve cover-to-head seal is often from the camshaft seal, and it blows back to where you see it.
#36
#37
Just a before and after pic of the engine bay from this series of repairs. Valve cover gasket and camshaft oil seal are on the way. Im going to paint the valve cover today and do the intake next week when i replace the intake gasket on good measure just so i doesnt blow out on me and cause problems in the future
#38
eek, I wouldn't use brake kleen on the engine, that stuff is way too strong for all the electricals and hoses and stuff. of course, the new eco-friendly 'kleen prolly ain't half as bad.
no, what I was talking about was a detergent degreaser. I've been using the 'Gunk' brand stuff in the trigger pump bottle instead of aerosol. squirt that on, optionally a bit of brushing, hose off.
#39
