Alternator...help !
Old Jan 29, 2020 | 02:15 PM
Sabukewicz's Avatar
Default Alternator...help !
I have a 1990 240 wagon
when I turn heater on alt charge drops to 12.5
I changed alternator and bat out
Could it be a short?
Please help...thanx
Old Jan 29, 2020 | 08:46 PM
The heater? or the heater fan ?
if the heater fan is drawing so much juice the alternator can't keep up, its possible its a bad fan motor, but its also possible there's a weak ground between the battery and alternator.
start the engine, let it idle, measure the voltage at the battery, and if you see that 12.5V, measure the voltage from the battery (-) terminal to the alternator body or ground stud. if that is more than 0.1V, the ground is bad somewhere between those two. measure the voltage from alternator ground to engine ground, and engine ground to battery (-) to see where to narrow it down.
240 fan motors are no fun to replace. it like they started with the fan motor, and built the car around it.
Infamous8973
May 30, 2019 07:38 PM
mrwrick
Jan 29, 2009 07:16 PM
briang232000
Oct 27, 2008 01:26 PM
vjking127
Aug 26, 2007 01:36 AM
