Alternator light lite on cold mornings
Old Oct 31, 2010 | 02:35 PM
calvinhoe's Avatar
Angry Alternator light lite on cold mornings
My 1988 744 alternator light comes on cold mornings. The gauges are dead when the light comes on BUT my temp gauge starts working (usually dead temp gauge when gauges are working). About a mile down the road, the light goes out and gauges starts working. I have tightened the ground screws at the alternator and at the battery-to-chassis ground. I cannot find fault when temp is in the 50's or higher. I drive 3.6 miles to work and the car has performed flawless ly otherwise. Great heated driver/passenger seats when cold.
Old Oct 31, 2010 | 03:14 PM
swiftjustice44's Avatar
This can be a variety of things but what I think of are 1. Failing ignition switch (the electric portion that fits to the back side of the actual key lock. 2. A bad ground on the cluster itself or where the cluster wiring grounds.
Old Nov 8, 2010 | 07:35 PM
calvinhoe's Avatar
Talking it's the voltage regulator
My mechanic said that replacing the voltage regulator would fix it. There are two carbon brushes. One was really short and was catching if I pushed it in. So for $35 I am a happy camper.
Now for the struts that hold the trunk up. I was replacing tail lights and the lid dropped on my hands OUCH so it's time to replace the gas struts.
Update: morning frost on car, 31 degrees were the combination that the alternator light comes on. Started the car and drove to work. Alternator light stayed off and worked fine.
Now, on with the temp gauge not working.
Old Nov 11, 2010 | 12:16 PM
bigdaddyrdpjr's Avatar
Temp gauge usually is the connector on the sensor rotten, or the compensation board behind the cluster (which can be fudged).
Akiles
2001-2013 model year XC70
Mar 13, 2015 10:29 AM
dman777
Dec 19, 2011 11:31 AM
c note
Oct 25, 2011 10:29 AM
coolson
Dec 10, 2010 12:35 PM
Mecheng
Feb 24, 2006 12:25 AM
