Alternator Whoes, regulator or wires or alt?
Old Oct 20, 2006 | 04:24 AM
kman3786osu's Avatar
Default Alternator Whoes, regulator or wires or alt?
SO, is the small wire thats connected separatly to the terminal that connects to the battery the positive lead from teh alt?
it broke off so ill need to reattach.
I am placing a new battery in the car and taking it to autozone to get tested, what should i have them look for as the cause for no charge of the battery?.....will they be able to tell if the ground, positive, or regulator is bad?>?
thanks
Old Oct 20, 2006 | 10:52 AM
dirt mcgirt's Avatar
Default RE: Alternator Whoes, regulator or wires or alt?
sounds like it maybe part of the charging wire
id replace it and see what happends and go from there
Old Oct 20, 2006 | 11:25 AM
AlexR's Avatar
Its called the exciter wire and yes if it breaks your battery will go dead. Fix the wire and as long as the battery isnt dry you should be ok. If it is low on fluid fill with distilled water only.
chompy
Apr 21, 2012 08:39 PM
overtorquer
Dec 20, 2011 09:38 AM
avguy
Feb 17, 2011 10:26 PM
240wagongirl
Feb 7, 2009 02:23 PM
redrider13
Mar 2, 2008 10:12 PM
