Assessing an oil leak
Old Jul 19, 2014 | 09:26 AM
Sourmilk's Avatar
Default Assessing an oil leak
Hello again- still trying to understand everything I should about this car and be as proactive as possible with my maintenance. I had my car on a lift recently to address the suspiciously absent rear muffler and my mechanic noticed a trace of oil which seemed to originate from the front of the engine (then went ahead and ordered a front crank seal from Napa). I checked under my car this morning and noticed a spot of oil towards the front of the vehicle smaller than a baseball. What I would like to know is, is this indicative of a more serious issue or should I simply replace the crank seal? I (of course) tested the crankcase pressure before purchasing and the PCV appears to be working fine, so could this just simply be an old seal? 1989 B230F, 169k
Old Jul 19, 2014 | 12:33 PM
there's three oil seals on the front of the engine that can fail with age... the crankshaft, the intermediate shaft, and the camshaft.
Old Jul 19, 2014 | 03:34 PM
lev's Avatar
lev
Hard to say which of the three has failed without taking off the timing belt covers. However, if it is the camshaft seal, the top one, there will be oil seeping down over the water pump seal O ring and it is easily noticeable. Either one of the other two, then it's a bigger job, like a timing belt replacement basically-- the oil then comes out of the bottom edge of the timing belt cover.
Old Jul 19, 2014 | 03:42 PM
and if it is the crank seal, its highly advisable to replace the harmonic damper aka crank pulley as the rubber core of those tends to rot out with age.
ROBLU540
Feb 20, 2009 07:59 PM
mkelly85
Jan 31, 2008 02:05 AM
pleonard
Jan 7, 2008 06:12 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
