Auto Transmission Probs:::
Old Oct 10, 2004 | 01:43 PM
FCHicks's Avatar
Default Auto Transmission Probs:::
Hello all:
I am having a problem on my 1990 245 DL-- shifting from 3rd into 4th and then to overdrive. The car seems to rev up too high in 3rd (45mph) and then finally shift into 4th...Overdrive usually changes into gear around 60-65mph..It seems like the car doesnt know what to do with these 2 gears..
Any ideas of what the prob may be?
Thanks::
CH
Old Oct 10, 2004 | 07:30 PM
Default RE: Auto Transmission Probs:::
How is the fluid level and color?Has the fluid been changed lately?You might want to have a trans shop look at it.If you take it to a dealer they will sell a fluid change then if that doesnt work they will sell you a trans.Volvo dealer ships dont rebuild transmissions they just replace.
Old Oct 10, 2004 | 07:33 PM
One other thing i forgot to mention is check the adjustment on the kick down cable and make sure its not frozen.The kick down cable should be straight not to tight and not so loose that is saggs.Pull on the cable and make sure it releases it should come up about 1 1/2 to 2 inches.Good luck
Old Oct 10, 2004 | 08:53 PM
FCHicks's Avatar
Thanks for that information!! I checked the trans fluid (with the engine running, correct?) and it seems to be full, but it is a brownish color. Sort of like chocolate brown. I just bought this wagon...so I'm not sure what exactly has been done?
That is good advise about the kick down cable...is that the cable on the drivers side under the hood on top of the engine that has a small wheel attached?? I'm not sure where the kick down is.
As for the fluid...I will have that all checked out!
Thanks again:
CH
Old Oct 10, 2004 | 09:19 PM
The fluid sounds a little burnt.I would have it changed.Yes the kick down cable is on the wheel on the drivers side if you follow the cables back the kick down is the one that is on a bracket with 2 13mm nuts pinching on the bracket.You just loosen one of them then adjust the nuts to tighten or loosen the cable. Good luck
Let me know how you make out.
Old Oct 18, 2004 | 12:04 PM
FCHicks's Avatar
Hi Tech::
Well you were right on!! Thank goodness the tranmission did not have to be replaced!
I had a fluid change and flush,,and the kick down cable was frozen up just like you said..The car is running like a champ now! Thanks for your advise,,I was able to communicate with the mechanic much more effectivley with your information..
Regards::
CH
Old Oct 18, 2004 | 09:17 PM
Your welcome,Im just glad i could help.
ajitaw
Feb 8, 2006 04:02 PM
Flashback
Nov 24, 2005 02:29 PM
Barrie
Apr 26, 2005 01:02 AM
willkula
Apr 25, 2005 08:58 PM
Sweet740GLE
Jan 8, 2004 02:13 AM
