b21 timing light jumps around 1981 volvo 245
Old Nov 28, 2024 | 08:46 PM
OldHippie's Avatar
Default b21 timing light jumps around 1981 volvo 245
Background.... The fuel injection system was hosed by previous owners. It was so far gone I ended up doing a carb conversion. It runs, I am driving it once in a while, but it keeps popping up with issues. Yes I know.... It's a 42 year old car, I should expect this.....
I am not sure if this engine has a distributor bushing, or what would cause this. With a timing light it is constantly jumping at idle between about 12 to 20, and it's confusing..
Worthy of note. This has a "FAST" Aftermarket ignition system.
Any suggestions?
Old Dec 4, 2024 | 03:04 PM
what kind of timing light are you using (ie old school where you induction clamp onto the #1 plug ? Are your power/ground connections clean? Does the idle sound smooth? What happens if you bring the car up to about 2000 rpm? Does your car have a vacuum advance to the distributor? Try disconnecting/ plugging that vacuum line before timing.
Old Dec 8, 2024 | 02:15 PM
OldHippie's Avatar
Ended up being a crap timing light Thank you for replying !
Dagaan
Oct 8, 2019 11:33 AM
daver80
Jul 29, 2019 12:08 PM
blondebrat72
Feb 22, 2011 05:18 PM
undercoverwalrus
Sep 25, 2007 07:26 PM
gmorgan
Engine & Internal
Jun 12, 2007 07:53 PM
