B21f swap into a wagon with a b230f
Old May 12, 2017 | 12:13 PM
Jonathan Jones's Avatar
Default B21f swap into a wagon with a b230f
I have 430k km on my b230f 740 wagon and I just picked up a b21f that was originally in a 242. I'm wondering how hard the swap is going to be and what else I need. I really love this car and truly want the 4 speed manual that's on the b21f to replace the auto in mine. Would the tranny swap be easier? My motor sounds fine so if the transmission swap is loads easier I might just do that. I have the engine with most accessories on it from the 240, the transmission, drive shaft and ecu
Old May 12, 2017 | 03:01 PM
thats a M45 4-speed w/o an overdrive? huh.
not sure where you'd find the right length drive shaft for that old 4-speed tranny in a 740, the 240 uses different length drive shafts than the 740 does..
I'm pretty sure manuals use a different final drive ratio than automatics, and the 700 series uses a different rear axle housing than the 200 series.
I would NOT put a b21f in a 740, you need all the horses you can get to move that big body.
what year is the 740? 89+ requires a flywheel with LH2.4 timing notches for the crank position sensor.
james130
Feb 3, 2017 10:56 PM
Lifelikeworm
Jan 30, 2017 01:09 PM
Jerry Keen
Apr 30, 2016 02:11 PM
SlickNerd
Jan 25, 2011 06:25 AM
Boricuaguy18
Engine & Internal
Jul 22, 2007 03:54 AM
