B230f to B230ft?
Old Nov 8, 2005 | 10:37 AM
Josh's Avatar
Default B230f to B230ft?
If i lower the compression of the B230f can i put a turbo on it? Or do the internals differ greatly from the B230ft and can't internals handle a turbo?
Old Nov 8, 2005 | 09:08 PM
Default RE: B230f to B230ft?
The block and internals will be fine. You will need to swap the Cam over as well as the turbo. And the computer.
Old Nov 9, 2005 | 03:36 AM
Josh's Avatar
Ok, thankyou.
Old Nov 9, 2005 | 08:10 AM
Josh's Avatar
i've just realised that the internals don't matter (as i will be replacing them). But is the block its self any different between the 2? (i will also replace the head with a B234 so that doesn't matter)
Old Nov 9, 2005 | 09:36 AM
They are pretty much the same.
I have seen B230's turned into B230 turbo's all the time with no problems at all.
Aaron480
Dec 7, 2008 02:58 PM
boostedbrick
Feb 23, 2006 01:30 PM
ezwilly
Sep 2, 2005 09:36 PM
Gogats
Aug 30, 2005 10:02 PM
Desperado
Apr 10, 2005 02:36 PM
