B230f vent on block????
Old Nov 20, 2016 | 04:15 PM
cadetgubbins@gmail.com's Avatar
Default B230f vent on block????
Hey guys I have a 91' 240 with a b230f and I pulled the down pipe off (from exhaust manifold to catalytic converter) and noticed a PCV valve looking thing behind the down pipe. This thing is on the engine block about oil filter height on the rear ish end of the block and it's got oil all around it and has nothing on it. It looks like there is a 1/2 inch nipple on it for like a hose or some thing but I don't know what this thing is???
Old Nov 20, 2016 | 06:29 PM
I think thats a drain to get the coolant out of the block when you're complettely draining the system. The Volvo equivalent of a PCV is the 'flame trap' and 'oil separator box' on the intake side, under the intake manifold.
Old Nov 20, 2016 | 06:42 PM
I tried to pull it out to see what type of value it was but as it was coming out oil started to gush out like when you pull the oil pan drain plug.
Old Nov 20, 2016 | 06:51 PM
the white valve shown here near the engine mounting flange is the coolant drain.
the open hole below it and to the right a bit is used on a turbo for the turbo oil cooling circuit.
Old Nov 20, 2016 | 06:57 PM
yes it is the white one not the turbo oil feed, weird when I cracked it loose oil started to drip down. But thank you for your help.
Stewart G. Griffin
Oct 18, 2017 09:30 PM
ginginboy
Feb 19, 2007 03:23 PM
Boss 302
Jan 24, 2007 08:40 PM
jakeman111
Feb 23, 2006 09:13 PM
Josh
Nov 9, 2005 09:36 AM
